I doubt specifically for the sub tank parts but it is possible. Thanks!... When the bits come I can happily write down all the part numbers for you. But til then I'd largely be guessing. It maybe that the left hand drive and right hand drive parts are different numbers?
Yes, definitely not the same thing, although i am also seriously considering your approach too. The sub tank item is further down on my to-do list so i have time to look from all angles.Hi Yaro, that article isn't really relevant to what I am doing. I am fitting a tank that is separate to the main tank. Rather than a tank that empties into the main tank to top it up via a transfer pump. When low in the main tank, there will be a dash switch that flips the change over valve so that the engine pulls from the other tank. There will also be a change over so that the fuel gauge also gets the signal from the spare tank. So no sub tank gauge, no transfer pump etc.
So we may not actually be attempting the same thing. Other than maybe the actual tank itself.
Maybe, this needs to be checked.I'm just throwing this out there -
...Would any of the bits be usable?
There is no V6 stock on an 80 Series, only straight 6 and V8. i think Jonnyboy talks about 95 series.I can't say what the differences are between petrol and oil. I didn't even know there was a V6! Shows what I know.
