I decided to make use of the warm weather and get the annual waxoyling done.
No matter how many times I do this job I never remember precisely how
disgusting a job it is!
I pressure washed the underside yesterday evening, that took me about an
hour and I then left it until lunchtime today to dry out properly.
Then the fun started!!
Within 10 minutes I had an eyeful of clear Waxoyl as I'd forgotten to put my
goggles on. It stings I can tell you!!
After scrubbing out my eye I put the goggles on and continued. Within 5
minutes the goggles were so caked in waxoyl that I couldn't see a thing; so
I decided to carry on without the goggles.
Not too bad once you learn how to dodge the ricochets and overspray and
avoid either choking on waxoyl fumes or suffocating due to a waxoyl clogged
breathing mask!!
I started with all the chassis rail internals which I liberally sprayed with
clear waxoyl. This bit took about an hour. Then I made my next mistake. I
sprayed the wheel arch undersides with a very liberal coating of black
waxoyl. Looks lovely, took about 2.5L for all four arches and does a good
job. The mistake was not leaving this till last because I now had a layer of
black waxoyl on the floor to lie in whilst I finished the rest of the
underside with clear waxoyl!! I ended up looking like one of the Black and
White Minstrels!
Anyhow, a liberal coat of clear on the chassis externals, underside, inside
the wings and inside the cills (sills? - I never know which spelling)
finished the job nicely. I then parked the beast on the road so that it
could happily drip away the surplus.
All in all the job took me three hours (four if I include the pressure wash,
and five if I include a long shower to dry and remove the B&W Minstrel
look!!
). I used 2.5L of Black and ~7L of clear Waxoyl.
At least that's over for another twelve months!
Pete
breathing mask!!
White Minstrels!
look!!
Pete
