If you test between the terminals at the bulb connector to earth you should find it pretty easily. Fit a relay in the engine bay and fuse the connection to the battery within 100mm of the battery terminal. Fuse where you connect to your high beam wire too (2A) and run the coil of the relay from that via a switch in the cab.
