Yep I have this version too. IIRC, It has a fuel pre -heater a bigger heater core and a rad roller blind.I was under the bonnet today and as I looked on its underside there was a sticker saying "SNOW VERSION"
Can anyone tell me what this is?
The ABS is disabled with CDL and will reset when CDL is unlocked as long as you haven't driven above about 40 mph for 400 yards. It's an odd thing, but keep the speed down and the ABS will come on and off with the dashboard switch. Go over the limits and it will only reset with the ignition. Not sure if that's a quirk or designed in.
700 mm.
I do use mine for wading. It's good at keeping the shite out of the rad. But I do think it was for faster warm up, originally.
I never got round to trying it out but I had an idea of cable tieing a short piece of perforated garden hose along the top of the rad with the holes pointing downwards and connecting it to my garden hose when I got back home after a 'muddy' and leaving it running for a while.A garden sprinkler post wading trip is a good way to clean out your rad. Don't use a pressure washer as they flatten all the fins bad block cooling too.
Mine's got a blind, it's down all year round & even in the hot weather the needle position never changes to when it's freezing cold.
