Rob
Obviously as big as I can I hear you say. Well yes but I need to keep Halina happy and I would like some garden left. I have put in planning for a garage with internal dimensions of 5220mm wide and about 5700mm long and I have been given the option to make it a bit longer without lengthening the application process. My concern is that it may not be long enough, with an 80 being 4840mm long and the 530d being 4805mm long and quite low (meaning that jack handle needs to be near horizontal) I am thinking I should make it longer. It looks like I will need to apply for building regs if I do but so be it.
I could stretch the internal space up to 6500mm but it will be difficult to justify to Halina. Assuming that I only intend to work on one end of the vehicle with the shutter door closed, what do you think is a sensible internal garage length?
BTW there is no driveway, the entrance will be on the rear access road (with plenty of room to turn it if you were wondering) so would prefer to be able to work on a car without opening the shutter, but would consider raising the shutters only when I need to lift both ends of the car and then close it.
