I have a wheel stud on the right rear that is fubar. Can't even get a thread restorer on it to try and fix it. Must have happened when I had the BFGs put on, and when I was moving tyres around today to get the same tread depth on each axle I discovered it.
So - how difficult is it to replace, and do I need any special tools, eg a press?
Should all 6 be relaxed at the same time?
Should I also replace the wheel nuts if I replace the studs (one is fubar anyway - the one that was on the fubar std)
Thanks guys
Thanks guys
