- Mar 7, 2010
What about unloaded? 15-20 psi with your 864's should be about the same as 868's. Do you carry a spare bag and have you had any failures?
I have about 8 - 10 psi whilst not loaded ie any running about that I do here, twin rear wheel / bumper carrier (freeways lattitude model) with just one wheel on in uk , LR tank usually about 1/2 full & general tools / spares etc in the back, so still quite heavy when 'unloaded'.
I have not had any failure of the bags, and no I dont carry a spare (but you have got we thinking now, maybe I should?!!)
I connected mine together, ie not individually to keep the pressures the same, and if one did fail, the pressure loss would be even (does that make sense?)
FYI I located the shrader valve for pumping up / down inside the fuel filler flap area which seems to work quite well.
They certainly keep the back up when very heavily loaded, and if you compare mine with a similarly loaded 80 with no bags the height difference is really significant.
I wouldnt go on a heavily loaded trip without them now............or the wholesale automatics valve body / lock up kit come to think of it!
Andy
