Lorin
- Mar 28, 2010
Drove the truck yesterday and it was absolutely fine. Started it this morning and it started perfectly, but when given any throttle it belches white smoke and stutters. To drive it is lumpy and gutless.
I had this same problem back in Sept after Lincomb viewtopic.php?f=15&t=12291 I took it to a diesel pump "specialist" who fixed it - I vaguely remember them saying something about the timing...
I have also had an intermittent fuel leak from the pump cover that reappeared today after having not leaked for several months. Not knowing if the smoke issue and fuel leak might be related I have just had the seal replaced. This has fixed the leak but not the smoke and power loss. However, when the top of the pump was removed it was evident that whoever was last in there (i.e. the "specialists" ) had sealed it with sealant and left a perished seal in place.
I have only driven around 1000 miles since the issue was last 'sorted' and given the indication of their workmanship I am reluctant to take it back to the pump garage. The mechanic who just replaced the seal advised me that the pump likely needs a rebuild
I'd appreciate any thoughts on this. Should I get the pump rebuilt or is there anything else that it could be?
