Brush up on the wheel-arches on the occasion of the new shocks and some rust problem in the cargo area
View attachment 113639View attachment 113640
You call that rust - PAH!
I'll show you RUST.
Bob.
The cruiser has 197,000 km, has been used often, but for short distances, when I went to see it the first time it struck me because it's completely original, the first and sole owner does not even have the radio mounted: the cruiser has remained as it left the factory. All in all it has modest wear and, rust aside, it's really well preserved.Looking beautiful Francesco, does it get driven much?
Workinig in the snow flurries was getting a bit tedious yesterday, so was a joy to be out in snow flurries and 40mph wind today. Trying to track down the mysterious grating sound from the drivers side.
Thought it might be a loose or worn top wishbone. Managed to snap a crowsfoot spanner tightening it. Then found a more likely culprit, a bit of flapping wheel arch trim. Thought I'd tie wrap it to the piece of trim behind it. Drilled a hole to secure it and promptly went straight into the washer bottle.
Wanted to get started on replacing my rear bumper light assemblies and then realized the rust on them was worse than I thought. It seems the light assembly fitting (square section) is half rotted out as well... hmm Do I take the chance and remove them and see what "fix" I can do, or just buy a new bracket.
Milner seem to be out of it, but from what I remember they had it for around 20 pounds each...
Oh well, I wanted to boast ... In reality the situation is not so dramatic. That's the consequence of a rough road maintenance: nobody spills the salt on the roads in winter and then, if the car owner keeps it under cover, a 30 years old car can develop little rust .
So, overall I don't think she's in too bad shape for her age. If all goes to plan, Wednesday evening is the plan to put the new suspension on......
Hello Rob. Is it the rear shocks that you are referring to?Looks a lot, lot better than my 99 plate 90 when I got rid of it 6 years ago. From memory the only faff on the 90 suspension is getting the top mount of the shocks off. Best to cut through them, near the top and push the remainder upwards rather than trying to undo the top nut (well try, but be prepared to give up quickly). Making sure you don't damage washers or bushes if your new shocks don't come with them.
Hello Rob. Is it the rear shocks that you are referring to? View attachment 113689
If it is, I was wondering how to get to this as I could just about get my fingers over the top of it and into the 'pan' that the top of the shock bolts into.....
Perhaps you may be interested an almost new mayor and some alderman for traffic and roads who could contribute to the elimination of the salt problem...Its looking lovely, I'm very envious.
Living in Scotland where we have salt on the roads for about six months of the year (bit of exaggeration) cars don't last long.
Bob.
