Windscreen Washer not working
Neil Cable
Hi
Window washers have stopped working I have checked board all ok I Know Switch on stalk is working because I can operate Headlight washers its not a blockcage as I cant hear pump running but I can when headlight or rear washer is running
There is a pump for each washer, windscreen will be the lowest. Find and unplug the connector to the pump motor. Test with a multimeter set to Volts across the contacts of the plug that comes from the loom while someone operates the windscreen washer. If Volts appear at this connector, check with the multimeter set to ohms across the motor terminals, you should get a few ohms resistance. If not, the motor is likely damaged and in need of replacement, if you do then there is possibly something jamming the pump. You’ll need to lower the level of screenwash and remove the pump to inspect.
