I have posted before about the ARB M002/4 wiring harness upgrades. This is a plug and play harness that uses the signal to your bulb to trigger relays and take a feed directly from the battery post via HD wiring to your bulb. I tried a quick experiment with a flying lead from the battery to the bulb and was surprised by the difference. The stock wiring is puny and if you go stuffing extra wattage lamps in there you may end up frying the spider silk wiring as well as the bulb connector as I have done before. OK, but the drawback on the very nice ARB one is the price. £103 in the UK.
I was idly googling this afternoon and came across this. Wowser!
http://www.eautoworks.com/Putco-H4--900 ... D7540.aspx
Duly ordered for silly cheapness. I shall give it a go and report back. It only does the outer lights which are dip and main and not the aux mains for the inner lamps. Well not yet it doesn't The ARB has three relays, so it must be more cleverer that this one. But for $37 it's got be worth a spin. I was looking on a Jeep forum from the search results and everyone said that this was a good piece of kit and easily as good as the ARB but a fraction of the cost.
Rock on
Rock on
