I'm in the throws of moding and repairing the rear lights on Fiery
I've completely removed the bumper lights repaired and refurbished them with rust-stop, paint and waterproof sealer and repaired all of the external loom light wiring from where the previous owner had botched the towing electrics into the loom with Insulation Displacement Connectors (Scotch locks). I've now also moved the original near side reversing light lamp holder down to the fog light position and rewired it so I have two rear fog lights now and I've replaced the reversing light holder on this side with a twin filament lamp holder 21/5w and have wired both filaments together to give me a 26watt reversing light and using Philips fast response twin filament lamps said to give 20% more light output I should be in theory getting the equivalent light output of 31watts.
Now I want to fit a reversing light into the off side upper light unit using the same twin filament fast response lamp method, but.................now a lot of you Chris, Bob, etc will know what I'm about to say as I've spent most of the morning searching both this forum and that other one reading about many of the findings of old on the SWB off-side reversing light wiring mistery and what is that dead wire in the plug meant to be for?
If anyone has the answer to this or a link to a descent wiring schematic I'd be very apreciative
Lets try to put this mystery to bed for good
