Chris Green90
Hi Guys, Ordered a wheel stud from Milners on Friday and it came yesterday but I am a little dubious about the quality and size of the splined bit. I used the method I was taught when I was 7 to put the new one in. Line it up and wind on a nut with some washers behind it and it should pull through. Is this right. Obviously the splined part looks to be bigger than the original as the hole has stripped away some of it. But the main thing I am most shocked at is that it snapped, I was putting much less effort into turning the nut than I would tightening them up when putting wheels on. So what do you think. Try Milners again or go to Mr.T
