Hello all. First, it's clear that I'm new here. lol
(20 mins later)
A few months back I bought a 1997 Land Cruiser Prado 3.0 TD
It was in good condition but needed some tlc.
At first start I could tell it sounded very loud. Heavy knocking. More like a tractor would sound...
It was "Ms. Daisy" driven on most occasions.
Was overheated once which cracked the head....That was replaced.
Ok. It ran good, but loud...
Also the 4x4 would not engage.. Light up orange...
....I bought it anyway...
Took it to a mechanic who said it was the piston and rings causing the loud sound.
When the engine was removed, two of the pistons were very worn,scuffed up,with rings seized.
All 4 were replaced..Overhaul kit, filters changed.
After putting the engine back in. The guy could not even get it started.
Lets skip the rest for now.....
Present day:
I have blanked off EGR. (Pipe broke on a 346 mile trip)
I've replaced the starter, which burned.
Ran good for a few....Then comes the white smoke.....
So after a little digging it turns out the turbo was leaking oil, from the oil return hose. (Was it aluminum flex hose?)Ive replaced that...with a Kinugawa oil return kit.
More white smoke a few weeks later.... Turns out. The turbo was also leaking oil into the manifold and intercooler... So I looked for a new one. Found one on ebay at a great price and shipped fast! Turbo is C12B.
But now I have an issue with the vacuum lines right above the EGR (still in place but blocked)....
Can someone please tell me where does it all go! lol One i see runs to the vacuum pump under the injection pump.
Most of the diagrams I find online are for a different model 1kz-te (without intercooler).
I have no idea where that hose is suppose to go. I also found the main one on the other side of that disconnected. (don't know the name..lol)
Well, I have more questions but I just spent the last hr and a half trying to give you all a little history on my project. I'd like to get the vacuum lines sorted then we'll talk 4x4 and crankshaft position sensor....
Hope someone is still reading this. Thanks for any assistance.
(20 mins later)
Present day:
