327 chev and a five speed hj47
Sammy hart
australia
Gday guys I've just finished the engine rebuild for my hj47 and am looking g to put a 5 speed and transfer case behind it wanting to know what 5 speed is recommended was thinking a 60 series box? Also any help with a handbrake set up will be great to thank you loads guys
Sammy in Australia
Rodger
Hi Sammy,
There is a company in Oz (Adams, I think but I'll try and check) who make adapter plates - Chevy to Toyota. I guess they would know the options available. If I can't find the name then worth a call to F'n'B.
As far as I'm aware the differences between a 47's box and a 60 box are just the number of gears so you may be able to use the shaft handbrake set up. 60s have the h/b on the axle but the axles are only 70mm wider so may be worth considering an axle swop.
Keep the photos coming
tonytoyota
Hi and welcom good looking 45 love all 40s have fun with it from Tony.
