80 series rear hub nut sockets
Jon,
Please put me on your shortlist. Any clue about the price?
Rgds,
Roman (London, UK)
'92 HDJ80 (auto)
On 10/1/07, Jon Wildsmith <[Email address removed]> wrote:
Add me to that please.
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
Jon
Can you add me as well, thanks
Jeremy
Jeremy llewellyn-Jones
Quoting Jon Wildsmith <[Email address removed]>:
Hi Jon,
Superb work, please put me down for one.
Toby
1990 HDJ80
Hi Jon,
I initially used a 55mm Draper socket for the front hub nuts (now
replaced with Snapon one).
Anyway, I used an angle grinder to cut the slots in the side of the
Draper socket so now it does the fronts and the back and I only have to
carry one tool around ;-)
The downside of the Draper socket is that it won't fit in the hubs of
1995+ 80s, although I have taken some of the edge off to make sure it
fits some of the 1992-1994 hubs that are a little tigher than earlier
ones.
Considering you don't really need to go much over 47ft/lbs on the outer
hub nuts I suspect the Snapon socket can also be notched without
falling apart when used.
You can see some nice blurry photos at:
http://picasaweb.google.co.uk/julian.voelcker/OddsAndSodsPics
07971 540 362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
Hi Jon,
ones.
07971 540 362
Hi Jon,
I find it fits well and like the multi function approach, although took a
little bit of trimming - having something that fits on 1/2" would be better.
It is a better option but I would be surprised if it fits - the rear nut is
about the same thickness as two front hub nuts and a star washer, but then
when you add the length of the three protruding bits I suspect that they may
interfere with the end plates.
07971 540 362
Hi Jon,
07971 540 362
As I can never resist tools could you put me down for one as well please
Jon. What sort of price?
Pete
That's OK, Jon. Please keep me posted.
Rgds,
Roman (London, UK)
'92 HDJ80 (auto)
Jon
Is this the same hub socket that fits the front hub? - ie the 54mm one?
Niall
Cheers Jon
Took me an age to source a hub socket for the front -
Haven't done any work on the rear axel yet....
Will give you a buzz off line if I need one
Good work!
Niallo
Do these sockets fit the older or the newer hub, or both? Cheers.
Clive Marks
No, I didn't miss it, haven't been able to get near ELCO since yesterday
afternoon.
Shall I send a cheque? How much p&p?
Pete
-----Original Message-----
Behalf Of Jon Wildsmith
Sent: 01 October 2007 22:41
To: [Email address removed]
Subject: Re: [ELCO] 80 series rear hub nut sockets
In case you missed it Pete, =A320 + P&P.
Jon.
European Land Cruiser Owners Mailing List Further Info:
http://www.landcruisers.info/lists/
Checked by AVG Free Edition.
Version: 7.5.488 / Virus Database: 269.13.35/1040 - Release Date: 30/09/2007
21:01
Jon
What about valve body telephone assistance/consultation/support/shoulder
to cry on then?
Do I get one?
On Behalf Of Jon Wildsmith
Sent: 02 October 2007 14:42
Subject: RE: [ELCO] 80 series rear hub nut sockets
Hi Toby,
It should be with you tommorrow. A little thank you for the valve body
loan.
Best regards,
Jon.
