[]80 tech][steering pump][
Hi Guys
As I have said before my steering pump leaks and has done for four years. I
would like to know if any one has had the same problem and if the additives
work. Could I use silicon sealer at the leaking seal to stop the leak or am
I being silly again. If any of you have any thought on it.
John C
92HDJ 80 1HDT Ireland
No Jon silicone sealant won't work. The shaft is rotating within the
seal, one or the other is worn and silicone won't compensate. You can
try the additives as they are cheap, some people have used a few drops
of brake fluid in the P/Steering fluid, this causes the seals to swell
and grip the shaft more tightly. I suggest a seal change.
Regards Gareth Jones '97 1-HDFT Newport S.Wales.
John
I remember someone saying that adding a bit of brake fluid causes the seals to expand, stopping the leaks.
I've just had a look on the 80s-Cool archive, try:
http://www.birfield.com/modules.php?p=3D/archives/cgi-bin/namazu.cgi <http://www.birfield.com/modules.php?p=3D%2Farchives%2Fcgi-bin%2Fnamazu.cgi&name=3DArchives&query=3Dpower+steering+leak+brake+fluid&idxname=3D80scool&max=3D20&result=3Dnormal&sort=3Dscore> &name=3DArchives&query=3Dpower+steering+leak+brake+fluid&idxname=3D80scool&max=3D20&result=3Dnormal&sort=3Dscore
(Sorry Julian, in HTML to try to prevent text formatting garbling the link.)
This gives two possible solutions: Lucas "Power Steering Leak", and "a few ounces of brake fluid".
And in fact for anyone on this list who hasn't come across them before these archives are very well organised and, more importantly, searchable. (See http://www.birfield.com/modules.php?name=3DArchive <http://www.birfield.com/modules.php?name=3DArchive&p=3D/archives/html/80scool/> &p=3D/archives/html/80scool/ (hope I typed that right, it's on a different screen)
Christopher Bell
Devon, UK
1996 1HD-FT
| Hi Guys
| four years. I
| the additives
| the leak or am
| Thanks
John,
check on birfield search, 80scool, 80scool_aus and i8hmud
Lal
-----Original Message-----
[mailto:[Email address removed]]On Behalf Of john byrne
Sent: Wednesday, March 30, 2005 7:32 AM
To: [Email address removed]
Subject: [ELCO] []80 tech][steering pump][
Hi Guys
John C
