Does anyone have a suggestion, The actuator appears to be stuck. I have removed the pin cover as per Shayne's helpful suggestion at Lincomb. I have read the post on the rear diff locker that he started .
The pin wobbles but thats it .. the rear axle is on stands the LL selected, Key in handbrake off. Pin stays out .... tapped gently, rocked WD'd, still sticks in the same place . Selector light flashing ... not steady red.
I noted the fact that these actuators come off in bits.
How about drilling a small hole in the top of the actuator and filling it with WD, will it run out somewhere before doing any good. ?
I could always plug it after. Any thoughts guys.
Rob
Rob
