Rob
Took my truck in for an MOT knowing full well that it will fail on ABS so I handed them a print out of the ABS section of the FSM and they decided to do the MOT first even though I asked them to look at the ABS first. Anyway they had a go at sorting it today and they did the following:
Swapped front sensors
Swapped rear sensors
Checked for continuity on the rear looms
They can't find where the connector is for the front loom, does anyone know where it is and if it is easy to get to? Also the only code they are getting is open circuit front left or rear right. Also should I move the sensors back to where they were?
Taking tomorrow off work and if this continues I will just have to do it myself and probably pay for the privilege. Getting a full set of sensors and looms delivered to my at 9am tomorrow so should have what I need to put it right.
