guyc
- Mar 29, 2016
My ABS light has started to make an appearance.
Sometimes when I set off and test the brakes, I can feel the ABS pulsing. It will do it a couple of times and then the brakes return to normal along with the ABS light coming on although not necessarily immediately.
Other times, the brakes work normally and the ABS light doesn't light up at all.
From searching the forum, I'm intending on approaching it in the following order:
Ask for help on the forum
Check for damaged wiring
Remove sensors and clean them
Remove shims if fitted
Ask for more help on forum
I keep reading about FSM's and the diagnostics box under the bonnet.
How do I get access to the FSM's - Factory Service Manual??
I've found the diagnostics box and from a previous post I've found the instructions on what to do:
"Connect Tc and E1 together and remove the short link. With the ign on check the flashes."
Does the FSM explain the flashes?
Guy
Guy
