...48530-69155 MARK 48530-60052. Is the first number the part number? And what does "MARK" mean and the number after it? Stamped on my new ones is 48530-60051. So you think they will do?...
I suppose a good part-guy at a dealer could answer this.
I'm guessing that the MARK ...-... indicates what the part is marked as, like in your case ...-...51.
I don't know for sure, but believe that they would fit, as I haven't heard of anyone not being able to swap 2nd hand ahc-parts freely.
I would just ask my favourite dealer.
Are your shocks leaking? Or is it just the rusted covers?
The problem with changing shocks is to get to the top nut. Easiest with a rachet spanner I heard, but they are not that common in sizes over 19mm. Isn't it 22 we need? When I did it last, I had the body lifted off the frame, so nada problema. There is also the method with drilling a hole in the floor, and get in from above, using a standard body-drain-plug size. You find details on mud.
If it is just the cover, you can cut off the remains with a small angle grinder and put in a plastic pipe. You need just the bottom end off for that.
