roy
- Feb 4, 2011
i have put some leak stopper and gas back into the air con system and the pressure is good and seems to be holding.
now that the system is pressurised again the compressor pulley is engaging and is screeching like mad when switched on.
looking at the pulley i can see that it is not turning freely with the belt and engages intermitently.
when it does engage the cold air is free flowing and then it will blow warm again as the pulley is not turning the compressor.
anyone any advice to this issue ?
i am woundering if i can replace the pulley system which i believe has a clutch in it ?
or is the whole compessor a single unit, if it goes , you need a full new one ?
not had a much experience with air con so any help will be appreciated.
cheers roy
cheers roy
