FSM says 11Lj555fjr said:how much tho?
Justin_Elliott said:FSM says 11Lj555fjr said:how much tho?
Can you tell if the coolant was originally Blue, green or red? Red is the highest performance stuff to use (red apparently contains additives/lubricants - but from a cooling perspective they're the same.)
You can't mix colours, so if you intend to change over you'll need to do some extra flushes to be safe.
