diggerdave
- Oct 5, 2014
I've got monroe shocks too and they seem pretty good. Not too expensive, nothing flashy but they do the job.
As for the fronts compressing the springs even a little bit, I really don't think so. You add the spacer at the top of the spring, between the fixed spring seat and the top of the spring. In order for this to result in any compression of the spring the bottom of the spring would also have to be fixed - i.e. you'd be adding a spacer to a spring sandwiched between two fixed points... but it's not! The bottom of the spring is the lower suspension arm, designed to droop with minimal resistance so all that happens is that your (say) 1" spacer results in the lower suspension arm moving down by 1". The spring stays the same length, and is compressed to exactly the same degree as if you had no spacer. That's my understanding anyway
I think I understand this stuff, but am happy to be corrected!
All that said, my truck is lifted with spacers all round. It rides harshly! But that is more to do with the cheap springs I used than anything to do with the use of spacers. I'm pretty sure that in general the cheaper the springs, the stiffer they are. Since spacers are the cheapest form of lift, there might be a correlation between the use of spacers and the use of cheap springs....
