ModelMakerMan
- Jun 25, 2011
Got in the car after work (not the LC, my little daily run around Seat Ibiza) and no headlights?! Full beam worked but no dipped beam on both lights, checked all fuses and couldnt see any blown ones so drove home on full beam with the beam adjusted all the way down.
Got home and checked fuses again, pulled the relays and checked them, checked the switch and wiring then checked the bulbs........ both blown wtf? Apparently this is relatively common with modern cars where both bulbs blow at the same time?? Why would this be and surely its a bit of a stupid thing have as a common issue?!
