------=_NextPart_001_01C6_01CA6129.7A1636B0
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
There are paints you can use which change color at different settings.
You will know if your over using the brakes though,a s they will fade, and
will take a lot more pedal
Effort to get them to stop.
In more extreme cases like when I have run them, the material cracks and
comes away from the backing plates
In little flaky parts, when they get overcooked, and the rotors have gone
brown and blue.
Darren McRae Ph 03 522 11 371
20Dowsett St South Geelong Vic 3220
_____
Behalf Of john
Sent: Monday, 9 November 2009 10:34 AM
To: [Email address removed]
Subject: Re: [ELCO] brake pads and size
Hi Guys
Just had a reply back from a guy and he says the Toyota pads are rated for
250/300 deg C.
Now I wonder what the Temp gets up to under normal/average driving.
Are pads that are 700 deg C proof an over kill or wise.
The only measurement I have made is that the discs burn my fingers after I
stop if I touch them.
I wonder is there a simple tool that could be applied to the disc after
stopping and would this give an accurate indication of the real temps
experienced in that area.
john92HDJ80 1HDT
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:v=3D"urn:schemas-microsoft-com:vml" xmlns
ffice
ffice" xmlns:w=3D"urn:schemas-microsoft-com
ffice:word" xmlns:st1=3D"urn:schemas-microsoft-com
ffice:smarttags" xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
<!--[if !mso]>
<style>
v:* {behavior:url(#default#VML);}
o:* {behavior:url(#default#VML);}
w:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
</style>
<![endif]--><o:SmartTagType
namespaceuri=3D"urn:schemas-microsoft-com
ffice:smarttags" name=3D"City"/>
<o:SmartTagType namespaceuri=3D"urn:schemas-microsoft-com
ffice:smarttags"
name=3D"place"/>
<!--[if !mso]>
<style>
st1:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;}
@font-face
{font-family:Calibri;
panose-1:2 15 5 2 2 2 4 3 2 4;}
@font-face
{font-family:Verdana;
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0cm;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:blue;
span.EmailStyle17
{mso-style-type
ersonal;
font-family:Arial;
color:navy;}
span.EmailStyle18
{mso-style-type
ersonal;
font-family:Arial;
color:navy;}
span.EmailStyle19
{mso-style-type
ersonal-reply;
font-family:Arial;
color:navy;}
@page Section1
{size:595.3pt 841.9pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 9]><xml>
<o:shapedefaults v:ext=3D"edit" spidmax=3D"1026" />
</xml><![endif]--><!--[if gte mso 9]><xml>
<o:shapelayout v:ext=3D"edit">
<o:idmap v:ext=3D"edit" data=3D"1" />
</o:shapelayout></xml><![endif]-->
</head>
<body bgcolor=3Dwhite lang=3DEN-AU link=3Dblue vlink=3Dblue>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>There are paints you can use which change
color at different settings.<o
></o
></span></font></p>
10.0pt;font-family:Arial;color:navy'><o
> </o
></span></font></p>
10.0pt;font-family:Arial;color:navy'>You will know if your over using the
brakes though,a s they will fade, and will take a lot more pedal<o
></o
></span></font></p>
10.0pt;font-family:Arial;color:navy'>Effort to get them to stop.<o
></o
></span></font></p>
> </o
></span></font></p>
10.0pt;font-family:Arial;color:navy'>In more extreme cases like when I have run
them, the material cracks and comes away from the backing plates<o
></o
></span></font></p>
10.0pt;font-family:Arial;color:navy'>In little flaky parts, when they get
overcooked, and the rotors have gone brown and blue.<o
></o
></span></font></p>
> </o
></span></font></p>
<div>
<font size=3D2 color=3Dnavy face=3DVerdana><span lang=3DDE
style=3D'font-size:10.0pt;font-family:Verdana;color:navy;font-weight:bold'>Darren
McRae </span></font><font size=3D2 color=3Dnavy face=3DVerdana><span
lang=3DDE style=3D'font-size:10.0pt;font-family:Verdana;color:navy'>Ph 03 522 11
371</span></font><font size=3D2 color=3Dblack face=3DVerdana><span style=3D'font-size:
10.0pt;font-family:Verdana;color:black'><o
></o
></span></font></p>
<p class=3DMsoNormal><font size=3D2 color=3D"#1f497d" face=3DVerdana><span
style=3D'font-size:10.0pt;font-family:Verdana;color:#1F497D'><img width=3D225
height=3D157 id=3D"_x0000_i1026" src=3D"cid:
[email protected]"></span></font><font
size=3D2 color=3Dnavy face=3DVerdana><span style=3D'font-size:10.0pt;font-family:Verdana;
color:navy'><o
></o
></span></font></p>
<p class=3DMsoNormal><font size=3D1 color=3Dnavy face=3DVerdana><span style=3D'font-size:
8.0pt;font-family:Verdana;color:navy'>20Dowsett St <st1
lace w:st=3D"on">South
Geelong</st1
lace> Vic 3220<o
></o
></span></font></p>
<p class=3DMsoNormal><font size=3D2 color=3D"#1f497d" face=3DCalibri><span
style=3D'font-size:11.0pt;font-family:Calibri;color:#1F497D'><o
> </o
></span></font></p>
</div>
> </o
></span></font></p>
<div>
<div class=3DMsoNormal align=3Dcenter style=3D'text-align:center'><font size=3D3
face=3D"Times New Roman"><span lang=3DEN-US style=3D'font-size:12.0pt'>
<hr size=3D2 width=3D"100%" align=3Dcenter tabindex=3D-1>
</span></font></div>
<font size=3D2 face=3DTahoma><span lang=3DEN-US
style=3D'font-size:10.0pt;font-family:Tahoma;font-weight:bold'>From:</span></font><font
size=3D2 face=3DTahoma><span lang=3DEN-US style=3D'font-size:10.0pt;font-family:Tahoma'>
<span
style=3D'font-weight:bold'>On Behalf Of </span>john
<span style=3D'font-weight:bold'>Sent:</span> Monday, 9 November 2009
10:34 AM
<span style=3D'font-weight:bold'>To:</span> [Email address removed]
<span style=3D'font-weight:bold'>Subject:</span> Re: [ELCO] brake pads and
size</span></font><span lang=3DEN-US><o
></o
></span></p>
</div>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span style=3D'font-size:
12.0pt'><o
> </o
></span></font></p>
<div>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span style=3D'font-size:10.0pt;
font-family:Arial'>Hi Guys</span></font><o
></o
></p>
</div>
<div>
font-family:Arial'>Just had a reply back from a guy and he says the <st1:City
w:st=3D"on"><st1
lace w:st=3D"on">Toyota</st1
lace></st1:City> pads are
rated for 250/300 deg C.</span></font><o
></o
></p>
</div>
<div>
font-family:Arial'>Now I wonder what the Temp gets up to under normal/average
driving.</span></font><o
></o
></p>
</div>
<div>
font-family:Arial'>Are pads that are 700 deg C proof an over kill or wise.</span></font><o
></o
></p>
</div>
<div>
font-family:Arial'>The only measurement I have made is that the discs burn my
fingers after I stop if I touch them.</span></font><o
></o
></p>
</div>
<div>
font-family:Arial'>I wonder is there a simple tool that could be applied to the
disc after stopping and would this give an accurate indication of
the real temps experienced in that area.</span></font><o
></o
></p>
</div>
<div>
font-family:Arial'>john92HDJ80 1HDT</span></font><o
></o
></p>
</div>
</div>
</body>
</html>
------=_NextPart_001_01C6_01CA6129.7A1636B0--
