Peter,
I can't remember what I paid at the time in Scotland but in the end had to
get it done at a Toyota dealer (but it was a pretty pence).
The mistake I make (at time did all front axle rebuild, rotors/calipers
etc.) was to allow all the brake fluid to drain out. Rebleeding the new
system didn't work. I got a MBC repair kit (pistons, rubber seals) etc. from
Christo but couldn't get that to work so in the end had to bite the bullet.
At the time I didn;t have the FSM so may not have done it right.
I still have the origonal MBC with the repaired kit lying around and u're
welcome to take it and see if u can get it working. U will need the FSM
(could copy pages etc.) to bench bleed etc. If u can get it working u can
send me some UK food supplies (T-bags etc.
I'll have to post from Colorado.
However b4 that u need to check (several steps in FSM to go thru) that its
not something else.
[Email address removed]
Lal
-----Original Message-----
From: [Email address removed] [mailto:[Email address removed]]On
Behalf Of Peter Browning
Sent: Saturday, May 07, 2005 3:56 PM
To: [Email address removed]
Subject: Re: [ELCO] Brake problem
Just hedging my bets here.....
Does anyone have a spare new or good secondhand brake master cylinder
available for sale??
Pete
Brendan Lally wrote:
Kinda sounds like a master brake cylinder problem!
Hope not as can be expensive - happened on mine.
Lal
[mailto:[Email address removed]]On Behalf Of Peter Browning
Sent: Saturday, May 07, 2005 3:33 PM
Subject: [ELCO] Brake problem
Changed all the brake pads on the 80 today, took it for a test run and
the brake pedal goes straight to the floor! There is braking but not much,
and there is back pressure on the pedal, but it still goes to the floor.
Now, I didn't disconnect any hoses, there are no leaks that I can see
and the brakes were working perfectly before I changed the pads. So why does
it now seem that there is a huge amount of air in the system?
I shall get an ezibleed tomorrow and flush the fluid through as it
looks a bit dark anyway but I'm just intrigued as to why it happened.
Any thoughts?
Pete
1995 FZJ80
-- European Land Cruiser Owners Mailing List Further Info:
http://www.landcruisers.info/lists/
Checked by AVG Anti-Virus.
Version: 7.0.308 / Virus Database: 266.11.6 - Release Date: 06/05/05
not something else.
Lal
Pete
Lal
Any thoughts?
Pete
1995 FZJ80
