Tommo&Claire
Inspired by Matt's experiences driving down through Africa and that horrendous road in Kenya, i was having a conversation the other night which illustrated that i still don't really understand suspension differences and why...
I know it's all to do with unsprung weight etc, but i still can't get my head around it.
Example we were discussing...
If you barrelling along in an 80 on that road and hit a bolder, would the weight and subsequent inertia of the much heavier live axle setup try and crash the bolder out of the way, causing damage, where as a 90, 100 or 120 with IFS would bounce over it with maybe lesser amount of damage because of the lower unsprung weight?
OR
Does the heavier duty setup of the live axle mean you are less likely to damage something?
The maths suggests the former probably is true, lower unsprung weight means less force is transferred when it hits the bolder. However common sense seems to suggest the heavy duty live axle is simply stronger and therefore less likely to be damaged?
Thoughts?
OR
Thoughts?
