warrenpfo
- Jul 21, 2010
The 100 series has 3 bolts with captive nuts on the front cross member that help hold the “bash” plate on. In the process of removing the bolts all 3 sheared off and so yesterday I decided to drill and tap them out.
Its not the easiest of jobs lying on your back drilling up and after I managed to get the first one out successfully I started on the second. I managed to drill the initial pilot hole without a problem but on changing up to the next bit and having got half way through the drill bit snagged and broke. It did fall out and is now stuck up in the whole with now way of me getting it out.
I went on to the third bolt and the same bloody thing happened so I now have two broken bolts with bits of drill bit stuck in them and no way of getting them out. Both bolts are flush so no chance of welding a bolt to them.
Can you get a drill bit that can drill through a drill bit or what are my options.
