I have a Sony 6 changer unit the one as fitted to the 120. Not sure it was ever used. If that helps. Dunno what was fitted to yours but Sony seemed to be OEM fitment.
Is that 6-in-dash or the changer between the seats?
I think that if it is the type with the separate changer, you can connect other changers (or other sources) to the same input. Do a search on mud.
The changer is in the cubby box between the front seats ,it was not responding so i had alook inside and found some no doubt important parts laying in the bottom of the changer any help much appreciated
JOB DONE cheers zeusv8 i got your changer in to my car last nite ,fitting was no prob but for some reason my car came up with a fault but then on the way home it decided to work spot on ,im very happy with it now thanks again James
