Ecky Thump said:It is a 2-DIN hole for the larger units. I fitted a Sony in the wife's 90 and transfered it to the 80 no issues.
Trouble with fitting a CB is if the CB is single DIN and so is the radio the hole is slightly less deep than needed. I had to shave off about 2mm of the surround in my 80 to fit both in. The hole in the dash behind the panel is plenty big enough for 2 x single DIN if you need it.
Might be.sae70 said:Must be the left hand / right hand drive thing![]()
Use them like before.sae70 said:What will you do with all of your heater controls then KZJ![]()
