While on a little laning trip at the weekend I engaged rear diff lock for a short while but when I got back to the road it wouldn't disengage and made the drive home a little interesting
I managed to remove the actuator after a few sheared bolts which seems to be the norm with most jobs on this truck
and I managed to release the diff lock
The actuator had coroded where it meets the axle that much that a hole was there ally and steel just dont get on
The thing looked like it had come from the bottom of the sea I didn't hold much hope of repairing it but at £400 I was having a go
After a few more sheared screws I got it apart and it didn't look much better inside and the magnets in the motor had come detached then I remembered reading in an old post about some one glueing them back in position
After a lot of cleaning up the motor and a bit of tlc it worked so the rest of the gear body was cleaned up and the hole repaired with plastic metal and its all back together again and working fine Ive repainted the hole thing and put loads of copper slip between it and the axle
Thanks to whoever it was that put the post on about repairing the actuator
and dont throw your old units away have a go at repairing
