connection of spots
Hi Guys
I was just wondering if anyone knows what the headlight relay in the black
box on the passenger side in the engine bay would be capable of
withstanding.
Could you connect spots to this relay or would that over power it or blow
it.
john 92HDJ 80 1HDT
John,
That relay or two relays (in case of dim/dip setup) are hardly good
enough for OEM headlamps.
Haven't you had problems with the lights in the past because of the
relay getting hot and failing?
You'll need a separate power relay for the spots, rated at least 40A.
Rgds,
Roman (London, UK)
'92 HDJ80
On 3/26/07, John Byrne <[Email address removed]> wrote:
it'll blow if you run spots through it, or else the column switch will blow.
