http://forum.ih8mud.com/showthread.php?t=3D107438&highlight=3Dflush+radiator
http://forum.ih8mud.com/showthread.php?t=3D90919&highlight=3Dflush+radiator
http://forum.ih8mud.com/showthread.php?t=3D8905&highlight=3Dflush+radiator
http://birfield.com/modules.php?p=3D/archives/cgi-bin/namazu.cgi&name=3DAr
chives&query=3Dradiator+flush&submit=3DSearch&idxname=3D80scool
Have fun
-----Original Message-----
Behalf Of Brendan Lally
Sent: Wednesday, October 25, 2006 2:44 PM
To: [Email address removed]
Subject: RE: [ELCO] Coolant Draining
Its tricky 2 see. Mines a US 96 Petrol so maybe a little different than UK
one.
The stop cock is a white plastic "key" that=92s about 2" long at is near the
bottom of the radiator on the inside (i.e. facing the engine). U can c it
easier if u take off the stone guard from underneath (covers belts) and then
look back up (while lying on the ground) towards the left side.
U can also (barely) see it if u lean over the top of the rad and look down.
Its on the bottom right. Its quite hard 2 get 2
There are several writeups on 80scool and ih8mud regd. This. Ensure u drain
the engine block drain plug (access thru drivers side wheel well) as part of
it. I have a prestone kit add-on that attaches to the heater hose and allows
u to flush with the water-hose connected - so that=92s makes it easier.
Its easy enough (once u can get at the stop-cock) just several steps u need
2 take. Also ensure u run your inside heaters (incl. rear seat heater if
any) 2 help get all the fluid thru the pipes
Have fun
Brendan
Behalf Of markandsofi
Sent: Wednesday, October 25, 2006 2:31 PM
To: ELCO Mailing List
Subject: [ELCO] Coolant Draining
Hello everyone,
Newbie to the List here.
Can anyone tell me where exactly the coolant drain cock is on the engine
block of a 1996 4.5l petrol.
I had a quick look earlier (in the rain) and could'n't see it.
Any tips on draining, flushing and re-filling appreciated.
Marko
Linlithgow, UK
1996 FZJ80 Auto LPG
Checked by AVG Free Edition.
European Land Cruiser Owners Mailing List Further Info:
http://www.landcruisers.info/lists/
