Memory is a terrible thing, the left right adjuster can be found on the top outside corner on the back of the headlamp facing the battery close to the wing.
It is effectively unmarked as it pokes through a hole in the metal.
It's easier to find if you remove the headlamp from the car
Yes cross eyed. The beams were only about 20 foot in front of the truck since it had a suspension lift( not by me) should have been picked up on the MOT also the OSF main beam bisects the NSF after about 30 ft.
