Paddler Ed
1970s the large 4x4 market was dominated by the Series Land Rover, Nissan Patrol G40 and Toyota Land Cruiser 40/50 series - all much of a muchness in terms of simplicity. However, LR were still running 2.25 petrols/diesels, and rarely 2.6 6 cylinders... and playing with the Rover V8... except in Australia where they shoved a Holden motor in... In the back ground was the Range Rover and Mercedes G-Wagen (which hadn't found it's space yet completely)
1980's was the split into utilitarian lines (40 and 70 series (heavy)) and civilised (60 series and 70 series (light)) Land Cruisers in a number of different wheelbases, Nissan stuck to running the MQ and then the GQ Patrol; both of the Nissan offerings did ute and wagon, SWB and LWB. GQ also went to coils before the LC. Land Rover had the Range Rover moving up market in that time. Misubishi was just bringing the Shogun/Pajero online, as a civilised option. Don't forget Isuzu had the Trooper out at this time as well. G-Wagen was still ticking away in the background during this time - sold in the UK via Mercedes Truck dealers... but then it started to get really messy - Land Rover had found the Range Rover moving upmarket, the Trooper, Shogun had found a niche for comfy offroaders without load of exposed metal... Cue the arrival of the parts bin special... Yes, the Land Rover Discovery (Maestro van, Morris Marina and Sherpa vans all gave parts to it...). Also at this time Daihatsu was making tough little things (Scat, Foutrak/Fieldman) with decent engines in them.
1990's The market got a bit more confused - Toyota had the Land Cruiser II in the UK, Prado/Bunderra elsewhere, 70 series Land Cruiser and then the 80 series (later on the 90 series came into play as well) - but the others stayed around and all tended to get a bit softer (Shogun and Trooper). G-Wagens were still lost - as with all Mercedes products they struggled with the German market workhorse image and the rest of the world luxury market. Nissan had the GU Patrol coming out, still with a big engine at first with a smaller option. Don't forget the Nissan Terrano II with the TD27 (2/3 of a TD42) Daihatsu started to exit the market a bit, completely out by about 2001 IIRC.
2000's The split of the Land Cruiser range into 70, 80, 90 was completed, whilst Land Rover was a bit lost. Isuzu was exiting the market, and Nissan was getting it wrong with the ZD30. LR was moving things more and more upmarket with the Range Rover, and the Discovery was heading that way as well as the 7 seater option. Defender was still a workhorse, but the engine choices were never developed enough as Ford forced their engine solutions onto all the companies in their ownership, even if they were near ready, if there was something already around. Toyota still had the 100 (and 105 series) available in a fairly basic form in some markets, but other markets got the luxo versions (Lexus versions available from the 80 and 120 series)
2010's: The shift upmarket of nearly everything except for the Defender and the 70 series in most markets - however, the Defender got a re-birth as a Chelsea Tractor at this stage as well. G-Wagen finally found it's niche in a similar way... Others have continued as before, some getting softer (Shogun) and more car like, others might not be changing that much.
So, after that ramble what does it add to Brian's original comment... Well, I think that the 80 series is what the Range Rover should have morphed into in the late 1980s (when Rover was broke), whilst the Discovery is a competitor to the Collie - the 70 series matches the Deafener better in terms of modularity and wheelbases. Also, the ~100" wheelbase of a 73/74 is about the same as Discovery (and therefore the original Range Rover) - which means that the 'Light' L/KZJ73/4 is a direct competitor in terms of size to a Discovery, but down on seating.
But, did you know that a 2017 RAV4
-is longer wheelbase (by 80mm), is 55mm wider, 255mm longer than a FJ73/BJ74 Land Cruiser,
-is 120mm longer in the wheelbase, 27mm wider and 155mm longer than an original Range Rover
Something to think about when trying to draw parallels across the years...
