Drivers door C/L switch
Bounder
My drivers door c/l switch has developed a fault, it no longer unlocks the doors.
It will lock but not unlock them.
I removed the switch and desoldered the slide switch inside and checked it for function, it was 100% but the problem remained after I resoldered it and refitted it.
Anyone else had this problem?
Steve H
Do you mean the switch inside by the window switches? If so, check the bellows that fits between the door and the main pillar. Prise it off and check the wiring as it goes into the door. Mine had broken here and it also stopped the mirror adjustment and heated mirror circuit. HTH
Steve
Bounder
I got this fixed today, the wire had snapped inside the rubber bellows.
Unlock wire is the thin blue with yellow trace on my 1997 Swb 90
