Dan W
Hi, it's me again. Since I'm going to have a look at the diff lock sensor today, I thought I might as well make a day of it and address a couple of other issues.
Neither my heated seats or intermittent rear window wipers work.
With the seats the little light on the switch comes on but no heat. Same for passenger side. When you press it I'm assuming you should be able to hear a relay somewhere click, but it doesn't.
With the rear wiper, it works on continuous fine so it's not the motor, but again, no clicking from a relay.
Soooo.....could the relays for them be in the same spot and something's happened to them? I've done a search but can't find any info and it seems my FSM is missing some sections.
