- Mar 1, 2010
The return pipe washers are a cunning design and ought to be joined. When you do the bolt up the lower washer bites into the razor sharp square top of the injector. This stops it turning when tight. The link also stops the top washer tuning and the bolt is also gripped sideways as the top washer compresses. This whole thing stops the bolt from coming loose.
I've played the rising oil level and dropping oil pressure game.
