- Jul 15, 2012
HI Guys,
I attempted to change the fan belt yesterday. I undid the lock bult on the slider, undid the swivel bolt on the alternator and then wound the adjusting bolt all the way in to what I'm 99% sure is as far as it will go. After having some difficulty actually swivelling the alternator - had to get underneath and use 600mm breaker bar to swivel it - even though the swivel bolt was only finger tight. After all this I managed to get the OEM fan belts off with out too much trouble but the replacement Milner ones are just that little bit smaller and they just wouldn't go on (at least easily.) Could it be that they are just too small and the OEM ones had stretched? Or is it probably there is still some adjustment left in the alternator?
Any thoughts much appreciated.
