Lorin
- Mar 28, 2010
Following my trip through Europe in the 80 I thought I'd share some findings I had re the cooling system.
Prior to the trip I have never had reason to worry about the cooling system. It has been flushed, filled with proper red coolant and the truck always warms up okay with the gauge sitting at exactly half-way and never going any higher.
However, whilst sat in a traffic jam in 35 degrees I noticed that there was a considerable amount of heat coming through the transmission tunnel and that the gear-stick was very hot to the touch. Further investigation revealed that all along the transmission tunnel anything metal was literally too hot to touch. Yet the temp gauge had not moved and I hadn't heard the fan engage. I got out and checked under the bonnet and the entire engine and cooling system was extremely hot - way more so than I have ever seen it before. I turned on all the heater blowers and about 30 mins later there had been a noticable reduction in heat in terms of the gearstick and transmission tunnel.
Over the course of our trip I noticed that the temp gauge never went above or below half way once warmed up irrespective of ambient temp or the type of driving and that the fan never engaged (I never heard that roaring sound and could always turn the fan with the engine off. Also, the fan is always moderately stiff to turn but never gets any more or less with higher or lower engine temps).
Reading on other forums suggest that: (1) the temp gauge on 80s is notoriously bad and it is very typical for it to never go above half way even when engine temps go very high - there is a very strong case for fitting an aftermarket temp gauge, especially if doing a lot of driving in extremes of heat (i.e. 30 degrees plus); and (2) the indicated service life of the fan clutch is 100,000 miles and they should be replaced after this. Well worth checking if you're planning an extended trip anywhere hot. Given that my truck has now done over 140k it would appear that my fan clutch is indeed past it.
