I own a 100 series with solid front diff (105 series) and i have front free wheeling hubs fitted and part time gear fitted to transfer case instead of being full time.
Personally I prefer it, steering is lighter, yes you send all the power to rear so it cops a bit more but rear diffs are a lot stronger then front so I find that a bonus, fuel consumption isn't really any different. Wheel spin when pulling out, doesn't exist unless you have horrible tires and its wet. I have Cooper STT tires and even in torrential rain I rarely ever spin a tyre.
It is a slight inconvenience having to get out to lock the hubs when going off road but usually air down anyway so no extra effort.
Be warned though your ABS light will be on whenever your hubs aren't locked in, as your cv's no longer spin the abs sensor thinks your front tires aren't moving while your rear are going at whatever speed you are travelling, so you lose ABS but you can also buy a relocation kit for them if you wanted.
Personally I haven't, I don'd mind it but when its time for rego inspection just lock the hubs in before you go in and she'll be fine.
