anton
- May 20, 2018
Hey guys,
Been having a problem with the front end of my 80, any help would be great! She's a '94 FZJ80, manual with 240kms on the clock.
TLDR:
- Front end noise, happens above 40kph but only following 2 or more days of off-roading.
- It's really loud, vibrates the whole car and I often have to stop the car before the noise stops. After I've stopped I can set off again and it won't make the noise unless I go above 40kph.
- Pitch and volume of the noise seem to be related to vehicle speed (not RPM), suggesting the problem is past the gearbox.
- If I let the car rest for an hour or so it seems to be mostly fine and I can drive normally again.
- I have replaced wheel bearings and swivel hub seals, re-greased CVs, replaced diff oil.
- No metal shavings in the diff oil, and the diff gears look to be intact
My 80 has been making a nasty sound from the front end recently. It only happens after 2-3 days of off-roading, and is worst when I get back on the highway. I drive it around town all the time with no issues, but every time I do a trip more than 2 days this noise crops up again. It comes on above 40kph and I usually have to stop the car to make the noise stop, and then I can take off again and it's fine as long as I stay below 40kph. If I stop and let the car rest for an hour or two it tends to solve it and will only make the noise a few times for the rest of the day. It's a really loud grinding sound, the whole car vibrates. Taking the car out of gear or accelerating doesn't make it stop, and the pitch and volume of the noise seems to be related to how fast the car is going (not RPM).
TLDR:
