Craig, do you know what the difference is beteen the FT and FTE injectors? I have the opputunity of an incomplete FTE motor for about =A3400 / =A3450. It is - block, crank, rods, pistons, sump, some timing parts, head, valves, injectors and probably inlet manifold. No turbo and probably no injector pump.
It has taken a while to arrange a weekend when both I and the seller are both free plus I wanted to know if he had the injectors. So I am off to Devon next weekend with my trailer and some cash!
I had planned on getting one set of injectors overhauled then fitting them to my 80 1-HDFT. That way the vehicle is not off the road.
Mileages on the vehicles are - FTE 82 K - FT 103 K
Thanks, Gareth Jones.
