Getting rear seats out?
Gilbert v H
Apr 7, 2010
88
0
16
Aberdeenshire
I was trying to get the rear seats out today. Seemed pretty simply, till I came to the screws at the inner folding mechanism. Rather than 14mm bolts like the others, these are different and cannot be opened with a screwdriver or key. What instrument do I need for those, I've never seen anything similar?
Paul
I am in england
Mar 1, 2010
2,465
42
48
Southampton
Should be straight forward, mine had no issues coming out........
you don't mean the ones with the plastic caps you have to take off do you ;)
:cool:
Super Moderator
I am in europe
Feb 24, 2010
17,185
3,952
113
Chesterfield, Derbyshire
What - the very rear seats or the middle ones. Rears just unclip and the middles have four 14mm head bolts. Took mine out to get to the fuel pick up.
Dave Docwra
1,591
11
38
Enfield
Hi,You will need a strong pointed chisel & hammer, tap (thump hell out of it) the bolt arround until it becomes removable with a pair of vice grips, they are one way screw heads.
Super Moderator
I am in europe
Feb 24, 2010
17,185
3,952
113
Eh? I must be missing something. I just used a 14mm socket and unbolted them, did the fuel tank job and then and bolted them back in again. Must be some variations in design I guess. But mine were utterly standard fixings.
Rob
3,019
16
38
Bristol
get a photo on here so we can see what you are talking about. mine came out without any issues as well.
Bat21
I am in morocco
Feb 24, 2010
1,902
138
63
Shropshirington
+1 for the above.
It sounds like they have never been out before and the original Yota one way bolts are still in there.
Just thrash them out and replace with ordinary 14mm head bolts
Rob
3,019
16
38
Bristol
Probably changed it when Toyota introduced the bigger brakes and wheels as they both have the early model. anyone got an 80 which disproves this?
Paul
I am in england
Mar 1, 2010
2,465
42
48
Southampton
Normal bolts on mine (1995)....if we are talking about the ones through the floor.
The only troouble with mine were that the exposed part of the thread poking out under the truck was rusty and took a bit of force to get out.
Bat21
I am in morocco
Feb 24, 2010
1,902
138
63
Shropshirington
Jon Wildsmith said:
is it age related or that they're imports? I've never seen those used before.
Gilbert has a 1991 4.2 VX Limited and I have a 1992 4.2 VX Limited, so I guess it may be just the imports that had them Jon.... maybe just the early imports?
tomrichardson
i'm sure the only way to remove them is with something like the irwin bolt grips, or drill the centre and use a "grabbit" bit. you might be lucky using an ez out but i've never had much success with them and there are far better products around now. or as already posted, a hammer and chisel.
cheers, tom.
AdBlock Detected
