AndyCook
I was fitting a new switch on dash today to control winch in/out
i was testing it and unfortunately seem to have broken winch or solenoid...
its old warn winch of Chris's and his goldfish solenoid
i was running it one way, then pressed switch to wind other way when the which hadnt quite stopped spinning...
now solenoid just clicks when i use the switch or the remote
is there a fuse in the solenoid or have i bust something....
OK - I took dogs for a 10min walk, then tried the winch again, it spooled briefly then stalled again - solenoid just clicking. (I have disconnected the in-cab switch)
well i stripped all bumper off and metal underbumper, and the bugger worked perfectly for a few minutes..
then wouldnt work again
so i was going to check voltage to armatures with voltmeter and the git started working again...
GGRRR
annyoing being an intermittent issue, as bound not to work when i really need it...
GGRRR
