AGM
- Mar 21, 2016
First off, greetings from Georgia, and thanks to all on here that helped us to get on way to begin with.
Now for the problem: I have just noticed that we seem to be leaking a fluid (we think diesel) from the engine. Not technical in the slightest, so can't explain where from, but hopefully the below photo shows where the leak is coming from, which is worse when the engine is running.
Does anyone know what the problem is, and what work is likely to be involved?
Also, if anyone happens to know a good mechanic in Tbilisi (long shot I know!), then recommendations much appreciated!
Thanks in advance!
AGM
Thanks in advance!
AGM
