Thanks Clive.
I got it on the hoist to fit the new prop shaft to connect the motor to the transfercase.
So it needed to go from the motor.
To the input flange on the transfercase.
I found a Vitara front shaft was the perfect length, I just had to fit Sierra flanges and new uni joints.
This is the adapter I made up previously which allows me to bolt a Suzuki prop shaft to the motor.
Fitted.
With that done I could look at fitting the solar panels to the roof, which would first involve making a frame for them to fit to.
Cut and drilled some 2mm plate.
Bolted them on.
Bent some 25mm tube.
Welded it to the plates.
These are the panels for the roof and bonnet.
I bolted them all together.
And positioned them on top of the car.
Lifting all the panels up, bolted together made me realise how flimsy they were. So I decided then to make an alluminium frame for them, but more on that shortly.
I bent some more 25mm tube.
Got it on the bench to notch and shape the ends.
I could then weld it to the hoop.
I cut some 2mm plate.
Bent it to the shape of the panel and bolted it on using the M8 hinge bolts.
I added another M6 bolt.
Cut and notched some more tube.
I used a hole saw in the pillar drill to notch it.
I removed the windscreen.
Welded the pieces of tube in position.
To keep it looking like a Suzuki still, I was keen to follow the angle of the windscreen with the tube.
Cut, drilled and bent some more 2mm.
Bolted in position.
Cut, notched and welded some more tube in position.
And that was the cage complete.
Next job was to make an alluminium frame to go around the panels to give them some rigidity.
Using 40mm alluminium angle.
TIG welded it together.
Test fitted them over the panels and they fitted perfectly.
Next job was to work out where the mounts needed to be to mount the alluminium frame to the cage.
This is what we've decided to use.
With the position of all the mounts measured and marked on the alluminium frame, I could flip the solar panels over, drop the alluminium frame over them and then drill and bolt through the alluminium frame and the panels and bolt the rubber mounts on.
I could then lift the whole thing onto the cage.
The rubber quickfists worked well.
And the beauty of doing it like this is that when they park up in the desert to charge the batteries up, they can undo the rubber mounts along one side and tilt the whole bank of panels to face the sun. Adjusting the panels to face the sun increases their efficiency massively!
All that was left was for a few test laps around the carpark.
I need to mount 2 more panels on the bonnet.
Then I want to strip it all down and send the cage to be powdercoated and get the car ready for paint.
