- Feb 2, 2013
Landcruiser Handbrake Upgrade Kit for HZJ-FZJ75/76/78/79/80 Series | Superior Engineering
Huge range of heavy duty 4X4 accessories & suspension parts for most makes & models of 4WD vehicles. Buy online. Australia wide delivery.
www.superiorengineering.com.au
I actually thought this up 9 years ago !
Shayne
GuruJoined Feb 2, 2013 Messages 14,297
But while i was writing i had another (probably stupid) idea . If the handbrake gives up because of suspension flex then it seems obvious the cable is being over stressed which is why it pulls out and needs reset . You can't make the cable longer because then it wont work at all ..... unless , you alter the handbrake lever so the cable connects to it further forwards . This means when you pull the handbrake up your pulling more cable in to activate the brakes , but when you put it down your adding a few inches of slack which might be enough to let the suspension flex without harming the brakes .
