Ah... will learn to read when not half asleep one day!
A head 'should' last a lot longer than one year, but if you just fix a head gasket/cracked head and dont have a good look through the cooling system I guess it may go again relatively quickly, remember the cracked head/head gasket failure is usually a result of some other sort of problem that caused things to get too hot...
I did my head (using an AMC unit) and think the weak point on mine was the viscous fan coupling, it was definately low on oil, not easy to tell, I'm leaning towards fitting a far more accurate temperature gauge!
